CAT engine trouble
LAA
04-22-2008 10:03:38
D-399.Running hot on left exhaust bank and heavy black smoking. Turbo O.K. - changed nozzles that were burnt. Looks like fuel in the oil also.
DougM
04-22-2008 13:08:12
 Re: CAT engine trouble in reply to LAA, 04-22-2008 10:03:38
D-399, Is this a 6.25" bore 16 cylinder we are disscussing?.
If the turbo is good, check the aftercooler core for the turbo that feeds the LH bank for restrictions, also how are the air intake components before the turbo, ie filter, filter housing, intake air trunking if equipped.What intake manifold air temp are you seeing? what boost pressures are you seeing on each bank, exhaust temps on each bank. What is the load on the engine & what load is the engine rated for?
RENE'S
04-22-2008 10:15:09
HAVE YOU CHECKED AIR INTAKE?HAVE YOU CHECKED BOOST? CHECK NOZZELS THEN INDIVIDUAL FUEL PUMP PLUNGER HEIGHTS. DOES IT HAVE AIR RATIO CONTROL ON FUEL ASSY? IF NEEDED EMAIL ME. RENE' I HAVE THE BOOK.
