MF-54S BACKHOE ATTACHMENT
PARTIME
04-27-2008 09:22:13
HAVE A LEAKING HYD. VALVE WHERE THE DIPPER SPOOL PIECE EXITS THE VALVE BODY. HAVE REPLACED THE O-RINGS BUT NO HELP WITH THE LEAK. ANYTHING I CAN DO SHORT OF LOOKING FOR A REPLACEMENT VALVE BODY. ANY SUGGESTIONS APPRECIATED. RAY.Z.
steve n carol
04-29-2008 07:40:34
 Re: MF-54S BACKHOE ATTACHMENT in reply to PARTIME, 04-27-2008 09:22:13
Perhaps the "O" ring was damaged prior to or after installation. (the edges of the spools are sharp), and the slightest 'nick' will cause a leak. And as 135 mentioned, about the spool, get your glasses on and take a close look at it when you replace this "O" ring again...sl
135 Fan
04-27-2008 10:37:59
Maybe the valve needs to be honed or the spool is slightly worn. It might be worth it to take the valve to a hydraulic shop and let them have a look. I would think it could be repaired a lot cheaper than it could be replaced. Dave
