CASE 580 L
Robert Lafontai
04-30-2008 14:43:20
I have a Case 580 L backhoe for personal use on property the machine after it"s running for about 1 hour it will not move forward or reverse stop the engine count to 60 start machine and all ok for another while.Changed the torque,change the two magnets on top of transmition and still does the same. It"s just anoying am I missing something. Any idea what I should look for, Thanks Bob
chelsea
05-04-2008 10:32:16
 Re: CASE 580 L in reply to Robert Lafontaine, 04-30-2008 14:43:20
Thanks for the information will check on price for a new relay if too expensive will try one from another machine,and if that is what is wrong then I will buy, price for Case parts around here are VERY HIGHT was quoted last week $75-$80 for 8 plastic door bushing that are 3/8 dia. X 1/2 lomg, left them on counter will improvise at that price. BOB
AJ.
05-02-2008 17:16:05
I agree with Jfoshee that the shuttle interlock timer relay needs replacing,they upgraded that relay and it has a new part number 347706A1 Relay.
AJ
Jfoshee
05-01-2008 18:14:18
I used to run into something similar to this when I worked for Case. On the right side above the rear wheel is the fuse panel. Remove the cover. There will be several bosch relay's in there, but one is longer than the rest. Sorry, I don't recall it's exact position, but I'm pretty sure there is only one long one. When this relay would go bad it would not let the machine travel. All hydraulics and steering worked fine, but no movement from the transmission. I never had one to stop working then start again, but I couldn't rule it out either. I don't know how to check the relay and I'm pretty sure your Case dealer dosen't either, check the price of a new one, it might be worth a try to replace it.
Jiles
04-30-2008 19:46:27
Does your machine have the switch that deactivates the transmission? My 480D has two. One on the loader bucket leaver and one below and between the brake pedals. If you do, I would suggest you disconnect one or both the selenoid wires on the side of the transmission. If this is the problem suspect an electrical problem. Of course the selenoid could be bad.
