Transmission fluid in fuel tank...opinions?
Case450
05-06-2008 17:05:57
I was talking to a guy the other day and he suggested that in my old MF470 loader (perkins diesel) that I should put just a little bit of transmission fluid in the fuel tank when I fill it up. He said to do it every once in a while as the transmission fluid will help lube the fuel pump. Has anyone tried it?
teighs
05-08-2008 05:19:11
 Re: Transmission fluid in fuel tank...opinions? in reply to Case450, 05-06-2008 17:05:57
Try using biodiesel to replace the lubricity lost in the low sulfur fuel.
Link
hd6gtom
05-07-2008 08:12:33
Todays automatic transmission fluid has an abrasive agent in it to help keep the clutches from slipping. A little too much and you will be rebuilding pump and injectors. Would suggest a little non detergent oil or something simmilar, perhaps 2 cycle motor oil. I'm open to suggestions too.
marlowe
05-06-2008 17:30:07
been doing it for years also is a very good cleaner.the fuel we now get is real dry not a lot in it as far as lubricateing things my little case 450 like it and marvel mystery oil is good also
