Diesel fuel in engine oil
naz
05-08-2008 02:50:16
Hi, Can anyone tell me how fuel would get into my engine oil in my HD6 4cyl.Buda engine.Had a full tank of diesel over the winter and did not shut the fuel off at the tank.Went to check oil before starting the other day and found this.
Appreciate any help,
Naz
hector gemme
05-08-2008 09:47:26
 Re: Diesel fuel in engine oil in reply to naz, 05-08-2008 02:50:16
Yes it should be the fuel pump seal or if the the trottle lever was on all winter maybe the fuel transfer in oil.
ironman1953
05-08-2008 06:28:00
Had the same problem witha MasseyFergison backhoe. Its the new diesel fuel. When they took the sulfer out they put another addative in. Its so slippery that it leaks past the seals in the pump. Only way to stop it is to have the pump rebuilt. About $400 bucks here. Hope this helps you.
naz
05-09-2008 03:11:20
 Re: Diesel fuel in engine oil in reply to ironman1953, 05-08-2008 06:28:00
Thank you both ,I will check that and see if that is it.
Naz
