Crawler Hyd cylinder rebuild
PaulinLI
05-08-2008 06:37:33
I just dissasembled the hyd cylinder on my JD 420C. I removed the rod to put on a new seal kit. There is a star shaped nut on the end of the rod that i cant unfasten. Its a soft metal and has splines like a driveshaft. Any advise with this would be great. Thanks
original possum
05-08-2008 18:56:45
 Re: Crawler Hyd cylinder rebuild in reply to PaulinLI, 05-08-2008 06:37:33
Try the parts book pictures at the web site below.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt?irand=6040222724198667846
bcPA
05-08-2008 12:55:09
I wonder if you could use a pipe wrench to remove it. If the threads stick out beond the nut you could see if you can match it up with a new regular nut before you may destroy the old odd one
