450B dry clutch
Gus
05-08-2008 08:35:36
Bout knocked my teeth out bashing it in to a tree to free stuck clutch. Have sprayed lots of PB Blaster down in to it. Looking at the tech manual I don"t see how it could get to the discs anyway. So it"s time to bite the bullet and take it in. Don"t have the time to rip in to it and need it. $1800.00 was the estimate.Nice old machine but is a money pit.
hector gemme
05-08-2008 14:54:10
 Re: 450B dry clutch in reply to Gus, 05-08-2008 08:35:36
I am not sure with JOHN DEERE dozer but I tink you need too take off the final drive housing for removed the stering cluch.
jdemaris
05-09-2008 06:37:35
 Re: 450B dry clutch in reply to hector gemme, 05-08-2008 14:54:10
No, not true. With a Deere 450 - finals stay on and clutches come out the top - just like an Allis Chalmers. Deere 420, 1010, 350, and 2010 - finals do have to come off.
2010owner
05-11-2008 09:05:56
 Re: 450B dry clutch in reply to jdemaris, 05-09-2008 06:37:35
Just to clarify, on the 2010, as noted in the shop manual, "if only the steering clutch is to be serviced, it will not be necessary to remove the final drive housing from the tractor."
I've owned my 2010 since 1975 and have pulled the clutch pack several times, without removing the final drive.
B.
jdemaris
05-11-2008 10:56:53
 Re: 450B dry clutch in reply to 2010owner, 05-11-2008 09:05:56
On the 450 series - which is based on the 2010 but a bit different . . . all you have to do is pull the top pinion shaft out of the final drive after removing the three-bolt bearing quill. Then the steering-clutch assembly with brake comes right out the top.
jdemaris
05-08-2008 10:59:38
As least you can pull those steering clutches from the top without taking off the final drives.
If you drain the clutch housings once in awhile, and tie back the steering clutch levers when in storage (to take the pressure off the clutch disks) - it will never get stuck.
2x4
05-08-2008 10:30:13
welcome to the pit club.
Gus
05-08-2008 17:00:21
 Re: 450B dry clutch in reply to 2x4, 05-08-2008 10:30:13
Have put some serious money into it over the years. I might have earned almost enough to cover repairs. I'm not in to the major stuff myself.
2x4
05-08-2008 10:30:06
