Hi, I have a Case 580CK that has a boom jerkiness issue. With VERY timid movements of the control, the boom will work smoothly, but anything that resembles a normal control movement input, is greeted with an almost uncontrolled lurch of the boom. This happens both upward and downward. Loaded or unloaded. The D27565 flow restrictor is installed in the proper place and facing the proper direction. I am going to install a Parker variable flow regulator in each of the hydraulic lines that go to the boom cylinder. The regulators are rated at 3000 psi and 20 gpm, and I am going to install them at the cylinder ends of the hoses (not at the control valve end of the hoses). These flow regulators regulate flow in one direction, and freely pass oil in the other direction. The question that I have, is, does anybody see any advantage in having them both regulate FROM the cylinder, or having them both regulate TO the cylinder? By this, I mean, should the red arrows be the regulated side (high pressure oil going into the cylinder) and the black arrows be the freeflow side (oil that is trying to leave the cyliner), or vice versa? I can think of advantages each way. Thank you, Greg
