Eric, To go along with what jdemaris stated: the grease fittings he refers to are button-head fittings - not common ball-head zerk fittings. These rollers were to be filled with 90wt. gear oil, using an Alemite liquid grease gun. With very little seal wear, the 90wt. would run out, so it became common practice to use track and roller grease, or corn-head grease (used on combines). Later, Allis began installing factory-sealed rollers, which had no grease fitting - only a plug with an allen head. They were permanently filled with oil, and sealed with the plug. The plug was installed with an air wrench, and could normally not be taken out by hand. There was no need to lube them; if the oil ran out, the seals were worn out, and you were supposed to get a new roller. The seals were completely different than the greaseable units. The original seals were a one-piece, bellows-type seal, that were prone to being blown from not allowing the air to escape when lubing. The latter type - which is the only type now available - were two-piece machined rings, sealed with o-rings; they would allow the air past and settle back into place when lubing. I am not sure what type of seal was used in the permanent rollers - I would almost assume a double-chevron setup - but they were designed to only leak if the roller axle and bushing were worn out. I have never seen an after-market (Berco, Italitrac, etc.) roller for an HD3 that was greaseable, only the permanent rollers. You can always tell the permanent - they have plugs in the end. I know I've not seen everything, and I don't have the rollers in front of me; but, my advice to Rich would be to check the rollers for ANY slop of ANY kind first. If they are tight, I (personally) wouldn't fool with them. If Rich wants to try removing the plug from one or two to see what's in it, that's up to him. I don't see that it will hurt anything. I understand what you are saying about the rollers on your IH - some of the older ones were to be filled with oil periodically through the plug in the end; but, IH and Allis rollers are designed differently. As previously stated, the only rollers I've seen for the HD3 were either greaseable (from Allis), or permanently sealed and lubed (from Allis, and from after-market). My advice would be to check them for wear; if they are tight, run them. My $.02 worth, Dale(MO)
