JD 450g steering clutch
Cowboy Billy
05-13-2008 09:15:16
third party image
My Dad Brother and I bought a JD 450G dozer last summer. For our farm in Michigan's UP
Last fall when I went up and first started it and went to move the right track would not engage. I would pull the right track lever pull and release it and it would then engage and not have any problems.
This spring the same but worse. Now it is coming out of engagement while running it. If I pull and release the lever it will engage for 5 to 10 feet and then come out of engagement again.And some times when backing up over 20' or so it will load up the engine like it is binding.
Is this dozer strait mechanical clutch or hydrolic actuated.
I was told the hyd tank cap had came off two years ago and had gotten water in it. The fluid and filter had been changed. But the hyd filter light started coming on at the same time as the problem with the steering clutch.
Could this just be a adjustment issue. Or the clutch disk material coming apart. Or a actuator leak?
I run a cat D5M doing finish work but I do not know anything about JD dozers
Thanks for any help Billy
Roy Suomi
05-13-2008 15:48:39
 Re: JD 450g steering clutch in reply to Cowboy Billy, 05-13-2008 09:15:16
One thing to look at closely on the G series machines..Is rusted linkages..I've seen a couple of G's that burned out the brake bands and drums because of that..PD Mechanical hit it on the head with bent or loose/fallen apart linkages..
Roy Suomi
05-14-2008 15:50:02
 Re: JD 450g steering clutch in reply to Roy Suomi, 05-13-2008 15:48:39
Call me old fashoned , but I still like the 450-C dozer the best..I've heard people down the HLR transmission..They aren't a torque converter trans .I've done enough of them in my lifetime because of neglect mostly, that I can do them in my sleep..The 450-C has a lower , rounded nose and I believe a lower center of gravity..Just a sentimental old fool , I guess....
Cowboy Billy
05-16-2008 04:49:27
 Re: JD 450g steering clutch in reply to Roy Suomi, 05-14-2008 15:50:02
Roy I like a low center of gravity!!!! I had to do 1 on 2 slope last year 700' long 60' deep. That was enough to get me nervous. I used a D5M wide track for it. But there were times that I could not back up it.
I have never ran anything but a torque conv trans. But I thought because the 450G had long levers that is was mechinacial steering clutches. Some thing that would be simple for me to work on. All that fancy stuff can be nice until you have to work on it your self. The cat I usually run is electric over hyd controls. And when it messes up its call the cat mechanic time!!
Billy
Cowboy Billy
05-14-2008 06:30:50
Thanks Roy
Thats good to know. A good friend of mine says that the only stupid question is the one you should have ask but didn't. Those are the only two problems that I have found so far. The best way I know to fix something is to let those that know and are kind enough to help me out. Is to tell what it is doing and when and how it is doing it to the best of my ability. Other than those problems I love it. It starts right up in 10 deg weather. And is very controllable doing finish work.
Thanks again Billy
PD Mechanical
05-13-2008 11:01:38
Steering on the 650G is all hyd. with the exception of the control linkages. Problem probably lies within the steering control valve. Be sure valves are traveling properly, no bent linkage, etc. There are other possibilities as well, but start with the simple ones first. If you have any other questions or need parts feel free to contact me directly at sales@pdmechanical.com. Steve.
cowboy billy
05-13-2008 11:59:09
 Re: JD 450g steering clutch in reply to PD Mechanical, 05-13-2008 11:01:38
Thanks Steve
The dozer is 350 miles north of where I live. I am going up to the farm this weekend coming home tuesday. I will plan on checking the linkages. And plan on changing the hyd oil and filter. I was just thinking on draining the hyd tank or is there a better place to drain it. At this point all I have is the operators manual. Looks like I will need to get a maitence manual. Should I take a hyd pressure gage to check pressures on the valve?
I do not know if this has any bearing on the problem but the brakes do not work very well. It slipped my mind as I rarely use brakes on a dozer. The only time I used them on this tractor was parking close to the shed doors idling up to it to block them and barely got it out of drive in time.
Billy
ps I'll email you
