international 3616 backhoe loader
bruce L.
05-16-2008 19:07:36
looking at a 3616 with the d-236 engine are parts still available ?
any good or bad thing ?
jumps out of shuttle in foward but can be held in by hand
say has a bad injector can these be rebuilt or replaced ?
runs and drive old and worn $2500 for a homeowner hey for that i even get the straps welded to the gland nut.
thanks
bc
05-26-2008 08:04:52
 Re: international 3616 backhoe loader in reply to bruce L., 05-16-2008 19:07:36
Can't tell you much but parts are probably available.
I have a 2606 5 speed with a forward/reverse lever. Popping out of gear means there is a bad gear in the tranny. Could run over a grand in parts and a couple grand to fix. Got tired of holding in with my knee. For now, I drilled a hole in the side of the dash, put in a long bolt with washer and rubber hose on it. Bolt the right length and hole drilled in right place allows me to hook the lever over in front of the bolt and no more popping out of gear.
