JD 410 backhoe Hydro pump leaking.
hayrookie
05-18-2008 00:44:03
One of the big nuts on the front hydro pump is dripping a little. I have a new o-ring and white teflon piece that I got from the dealer. Do I just unscrew the plug and replace the o ring and teflon piece. I believe there is a small piston behind the plug. So I just wanted to find out the correct way to do this. Thanks
Roy Suomi
05-18-2008 04:22:21
 Re: JD 410 backhoe Hydro pump leaking. in reply to hayrookie, 05-18-2008 00:44:03
Yes , just unscrew the plug, replace the o-ring and teflon "skin" and tighten it back up..There is a spring and piston behind that plug..
