1960 440 ICD paint question????
Joe Kimbriel
05-18-2008 16:15:49
Getting ready to paint the old 440 ICD and found that the original paint looked pretty sickly yellow (bottom layer). Found Krylon had the same ugly yellow and called it John Deere Yellow. Is it true that JD painted these with this puke yellow?
If so, I'll let it happen and live with it.
Check the link, The blade is pretty close to original undercarrage,
Lavoy
05-20-2008 17:15:54
 Re: 1960 440 ICD paint question???? in reply to Joe Kimbriel, 05-18-2008 16:15:49
John Deere industrial yellow is still available from Deere, you get the yellow that is for prior to 198?, can't remember for sure. There are only two, and the later one is quite different. The original industrial yellow is almost orangish to a certain extent. If you need it, I have the code for the old industrial yellow in Martin Seynour.
430WLPG
05-19-2008 19:19:35
Mine is 461929
drrick
05-18-2008 19:30:41
early JD construction yellow was a bit more yellow than the current shade. I found that you can get real close with both "chrome yellow" and "school bus yellow" at napa. Do NOT use the ag JD yellow as used on the farm tractors.
430WLPG
05-18-2008 19:12:50
I also have a 1960 440IDC with a 831 loader, There weren't many made in 1960, I try to look at all I run across to to see if there is a newer one than mind left. If you don't mind what is your serial number? You want JD Industrial yellow any JD dealer can get it.
ralph newman
05-18-2008 21:34:27
 Re: 1960 440 ICD paint question???? in reply to 430WLPG, 05-18-2008 19:12:50
mine is 460028 with 831 loader. ralph i'm parting it out.
430WLPG
05-19-2008 19:24:30
 Re: 1960 440 ICD paint question???? in reply to ralph newman, 05-18-2008 21:34:27
Ralph where are you ? I need a RH final drive, Someone mixed up gas and diesel final drives and they don't have the same number of teeth.
Lavoy
05-22-2008 07:33:12
 Re: 1960 440 ICD paint question???? in reply to 430WLPG, 05-19-2008 19:24:30
All you need to do is change the gear set, you don't need to change the final case itself. I have gears on hand.
Lavoy
ralph newman
05-19-2008 19:36:14
SW OREGON 1-541-472-9196
430WLPG
05-20-2008 19:06:05
 Re: 1960 440 ICD paint question???? in reply to ralph newman, 05-19-2008 19:36:14
That's what I was afraid of, I'm in Sw Okla.
Joe Kimbriel
05-18-2008 21:26:06
Thanks guys. The serial number is 458083.
