Rusty c
berny
02-01-2001 17:10:02
i have a rusty c with no decals how do i define a c from a super c the only tags i can find on the tractor does not difine one from the other.
Wayne Swensn
02-01-2001 20:52:21
 Re: rusty c in reply to berny, 02-01-2001 17:10:02
Super C has disc brakes, C had band brakes.
casting codes
02-02-2001 02:10:34
 Re: Re: rusty c in reply to Wayne Swensn, 02-01-2001 20:52:21
disk brakes is good as well as casting codes. Under left foot on top deck is one of many cast codes
Pete
02-01-2001 18:01:44
Berny, Measure the grille screen part of your nose section, the Super C was taller than the C to accomodate a larger radiator. I can't recall at the moment what the measurements were, but if you go measure and msg back I'll look them up, or go measure mine.
Pete
Phlogiston
02-01-2001 17:21:16
Check the serial number. Also check to see that it has a water pump. However, C's could be fitted with a water pump later. The serial tag will tell. It is located on the right side of the tool box under your rear, if you are sitting on the tractor.
