Carburetor Choke
Bill VanHooser
02-05-2001 10:10:55
I have a 1948 Cub. There is a fitting/clamp that is attached to the exterior shaft of the choke valve for connection to the choke actuator arm. Does anyone know where you can buy a replacement clamp? It is a special clamp because it has the fitting to connect to the choke rod. It is also not part of the carburetor rebuild kit.
T_Bone
02-05-2001 10:29:54
 Re: Carburetor Choke in reply to Bill VanHooser, 02-05-2001 10:10:55
Hi Bill, I checked on trying to buy a new one recently and IH doesn't make one anymore. Junkyard or make your own. I'm going to make mine.
T_Bone
Charlie
02-05-2001 14:49:51
 Re: Re: Carburetor Choke in reply to T_Bone, 02-05-2001 10:29:54
How do you plan to make one. I have a similar situation with the coke cable on my 300 U. Its a swivel and I haven't seen anything I could use as a replacement.
T_Bone
02-05-2001 15:47:06
 Re: Re: Re: Carburetor Choke in reply to Charlie, 02-05-2001 14:49:51
Hi Charlie, Find one on another tractor and take a picture of it. They all work pretty much the same way. Just make it from a piece of 3/32" thick metal.
T_Bone
George Willer
02-05-2001 16:05:20
 Re: Re: Re: Re: Carburetor Choke in reply to T_Bone, 02-05-2001 15:47:06
T-Bone,
Check the last picture on the album for a picture of one I made. I used aluminum so it would grip the serrated shaft better. I made several at the time, and this one is the last one.
George Willer
George Willer
02-05-2001 16:03:42
T-Bone,
George Willer
T_Bone
02-05-2001 17:13:44
 Re: Re: Re: Re: Re: Carburetor Choke in reply to George Willer, 02-05-2001 16:03:42
Hi george, There you go. Easy pix to copy from and I'm sure he can make it from that. I didn't remember seeing that in your extensive album.
Mines a cable type and I have a proto-type already.
T_Bone
Greg
02-05-2001 12:59:55
T_Bone, you responded several months back in regards to the upper steering box seal on a Super A. Could you email me direct at tglaney@earthlink.net so that I might ask you a question regarding this seal? Thanks.
