12 volt wiring for Farmall m TRACTOR.
abane
02-06-2001 14:23:36
I need a wiring diagram for a 12 volt system for a Farmall M tractor.I have wired Farmall C tractors changing them over to a 12 volt system from a 6 volt system.I used a single wire alternator on my C tractors and this M has a double wire alternator on it.It is wired nothing like my C tractors. I wonder if they could be wired alike if I put a single wire alternator on the M. Can someone help me with this problem---thanks Al Bane
Drizler
02-06-2001 14:40:03
 Re: 12 volt wiring for Farmall m TRACTOR. in reply to abane, 02-06-2001 14:23:36
Did you look at the "RESEARCH & INFO " section to the left under ARTICLE ARCHIVES. Somewhere in there is a section on 12 V conversion and the diagram is for a "M". Thats the one I used to convert my 230 with a 2 wire Delco.
ABANE
02-06-2001 16:06:27
 Re: Re: 12 volt wiring for Farmall m TRACTOR. in reply to Drizler, 02-06-2001 14:40:03
Thanks, that was a big help.The diagram was plain and good.
