Cam timing
Bryon
02-14-2001 10:08:37
A couple of you guys said that you get better lower end with the cam set 7 degrees advanced. is there a way to tell if this has been done without pulling the timing cover and looking at the gears? My M at some time before I got a hold of it was bored to 4" and I wonder if the cam might be set forward too. Also, do you time the dist. the same with the advanced cam?
Phil Auten (TX)
02-14-2001 14:43:39
 Re: Cam timing in reply to Bryon, 02-14-2001 10:08:37
If you can get the original profile of the cam, you could check the opening and closing points of the valves using a degree wheel. Otherwise, remove the cover and check for an offset key or a wide slot in the cam gear.
As for timing, the distributor would have to be retimed to the correct marks on the crankshaft after the cam timing was altered.
4" sleeves are real common in M engines. I doubt that the cam timing has been changed unless the person you bought the M from was using it as a puller.
Phil
