Headlight switch terminals
Bob Burke
02-28-2001 03:30:39
My cub came to me with no headlights or headlight wiring. It is a 50's cub. The switch is a three position unit with a big alum knob, and looking at the back of the switch there is a term. #3 at 12 o'clock, a unmarked term. at 1 o'clock with a flat jumper to #1 term at 5 o'clock. Next I have a term #2 at 6 with another unmarked at 7. Then at 9 o'clock there is a unmarked term. with a spring wound res. that goes back to #3 I can get the lights to work using my cont. tester but I am unsure what the spring is for. My cub is now 12v neg ground if that makes a diff.
Bob M
02-28-2001 05:56:01
 Re: Headlight switch terminals in reply to Bob Burke, 02-28-2001 03:30:39
Bob - I emailed you offline a sketch I made of the backside view of the 3-position light switch all wired up. If you wire it correctly, front and rear lights are all on bright with the switch in the full clockwise (B) postion. The fronts are dimmed and the rear is bright in the middle (D) position. Full clockwise (O) all lights are off. ...Bob M
Bill C
02-28-2001 20:23:22
 Re: Re: Headlight switch terminals in reply to Bob M, 02-28-2001 05:56:01
I don't know about the switch wiring on a Cub,but,that is how the lights operate on my 51 H.
gene b
02-28-2001 05:24:20
the resistor terminal is for the rear light for dim the second pos on the sw will make the rear lite dim on the third pos is bright the resistor cuts the volts for the rear lite to be dim while the fronts are still on bright
Bob Burke
02-28-2001 16:05:37
 Re: Re: Headlight switch terminals in reply to gene b, 02-28-2001 05:24:20
Thank you for the help. I really want to see this all work.
