Order Farmall Cub Parts Online
Cub Clutch adjustment
Bob Burke
03-01-2001 16:43:07
I know that this has come up before but I will ask anyway. When I push the clutch down on my lo-boy it makes a banging, grinding noise. I have looked under the trans and it seems there it alot of wear left. Also how do you lube the pto shaft bearings. I havent had this thing long so I dont know when it was done last.
Red Raider
03-01-2001 19:32:45
 Re: Cub Clutch adjustment in reply to Bob Burke, 03-01-2001 16:43:07
Check to see if the clutch release yoke pivot pin (dead center of the pic) has shifted or the cotter pin has pulled out allowing the release bearing to slop around. Could also mean that one of the clutch fingers has worn out causing the noise.
third party image
