Order Farmall Cub Parts Online
Farmall Cub Wiring Diagram
Brian Randall
03-03-2001 06:31:43
I would like to know how to wire the generator and voltage regulator on my Farmall Cub. I have two wires coming from the wiring harness. One appears to be connected to the amp gage and the other to the light switch. I am not sure how to connect these wires to the generator and/or regulator.
Bob M
03-03-2001 11:41:55
 Re: Farmall Cub Wiring Diagram in reply to Brian Randall, 03-03-2001 06:31:43
third party image
This one's from the A/B manual. If your Cub has a 4-position light switch it will be wired the same. (Thank's to Farmer Bob for scanning this image!)
The Red
03-03-2001 06:43:15
Brian do you have a four position light switch?
Brian
03-03-2001 06:57:13
 Re: Re: Farmall Cub Wiring Diagram in reply to The Red, 03-03-2001 06:43:15
I believe it is a four position light switch.
The Red
03-03-2001 07:03:37
 Re: Re: Re: Farmall Cub Wiring Diagram in reply to Brian, 03-03-2001 06:57:13
I'll email you a picture shortly. I can't get the picture tag to work from my geocities site. The wire on the ampmeter post goes to the "bat" terminal on your voltage regulator. The wire that is hooked to that lower resistor goes to the "field" terminal on your generator. The 4 positon switch is low charge, high charge, dim lights, bright lights.
Robert Campbell
03-29-2002 09:18:37
 Re: Re: Re: Re: Farmall Cub Wiring Diagram in reply to The Red, 03-03-2001 07:03:37
Could you please send me the wiring diagram a.s.a.p. Thank you very much.
Robert
