6v. hookup
Ben
03-04-2001 18:48:41
Ok guys I have been scratching my head on this one and i need to ask the experts. On 6 volt diagrams I see that the positive side of batt. is ground, negative is hot side. On my H, it is hooked up negative ground and positive from batt. to starter button. Now did i hook it up wrong when i put on new cables, it has been a while and i think i put them on the way the old ones were hooked up. Could it have been changed over to neg. ground? What components could i have messed up, hooking it up this way??? Any info will help.
gene b
03-04-2001 19:25:41
 Re: 6v. hookup in reply to Ben, 03-04-2001 18:48:41
they are both pos gnd if you will look on the bottom of the reg it will tell you pos gnd you never know what some one else has done they are supposed to be pos gnd after you have have it right polarize the gen by jumping from the batt to the arm term on the batt of the gen DO NOT JUMP THE ARM TERM
gene b
03-05-2001 09:36:27
 Re: Re: 6v. hookup in reply to gene b, 03-04-2001 19:25:41
what a dummy me i meant not to touch the FIELD term the regs do not like this at all
ltf in nc
03-04-2001 18:58:19
Was the electrical system charging prior to this observation? If so, and you do not want to work on the system just hook it back with the replacement battery as you found it. It really makes little difference and can be made to work in either polarity
