Horsepower of farmall 350 diesel
a bane
03-05-2001 13:09:51
what is the horsepower of the farmall 350 diesel tractor
dick
03-06-2001 06:39:33
 Re: horsepower of farmall 350 diesel in reply to a bane, 03-05-2001 13:09:51
350 Farmall diesel, 1750 RPM (NTT #609): PTO: 38.65 Hp Drawbar: 36.26 Hp
International 350 diesel utility, 2000 RPM (NTT #610): PTO: 42.89 Hp Drawbar: 40.42 Hp
Horsepower are maximums obtained under test.
AGEN
03-05-2001 14:01:48
International 350 (same as a Farmall 350) has 42.89 PTO horsepower and 40.4 drawbar horsepower.
dick
03-05-2001 17:10:24
 Re: Re: horsepower of farmall 350 diesel in reply to AGEN, 03-05-2001 14:01:48
I think sammy the Red is correct - at least on the gas models the International versions were governed at 2000 RPM under load versus about 1800 for the Farmalls, which gave the Internationals (utility models) a bit more HP. I think the diesels worked the same way. I've got the Nebraska Test Data for both at home - I'll try to remember to dig it up tonight.
sammy the RED
03-05-2001 16:52:06
They are not the same. The Farmall had less horse power.
AGEN
03-05-2001 17:58:52
 Re: Re: Re: horsepower of farmall 350 diesel in reply to sammy the RED, 03-05-2001 16:52:06
You gentlemen are correct. The Farmall most likely does indeed have slightly less power than its International counterpart. I happened to have the International figures in from of me at the time so I used those. They give a general figure of horsepower. I stand corrected.
