Dipstick on M
ben
03-05-2001 14:09:16
Was a disptick an option on a M? I have a 41 M that has both the petcocks on the pan and a dipstick?
-thanks
Dan
03-05-2001 20:59:37
 Re: dipstick on M in reply to ben, 03-05-2001 14:09:16
Where is the dipstick located? On my SMTA the upper petcock was replaced by a fitting with a dipstick in it. Have seen them used on the old JDs that used a similar setup to check oil. the plug was taken out and replaced byt this gizmo with a dipstick in it.
Bill {Antique Acres}
03-05-2001 17:42:00
The dipstick was a aftermarket option. My Grandpa put one on his M. Bill {Antique Acres}
03-06-2001 07:50:09
 Re: Re: dipstick on M in reply to Bill {Antique Acres}, 03-05-2001 17:42:00
His went in place of the top petcock on the oil pan. Bill {Antique Acres}
Maybe
03-05-2001 15:05:53
maybe a replacement block from a power unit? 50+ years sees many repair\replacements?
FM
03-05-2001 15:05:20
I have a 41 M with an International replacement engine.It has a place for a dipstick as well as a fuel pump and other items i cant remmebr right now.Could be someone added it.The liftall pump had a dipstick as well.
The Red
03-05-2001 14:45:05
Not to my knowledge Ben.
Frank Bolder
03-06-2001 04:52:59
 Re: Re: dipstick on M in reply to The Red, 03-05-2001 14:45:05
I believe most M's (and H's) had an angled flat spot cast in the block that was, on later models, the location for a dip stick. Surely someone has drilled a hole at the proper angle and stuck a 460 dip stick in! Wonder what else the drill would hit? How did he calibrate the depth of the stick? Another great "cottage industry web site" for some upgrader. D-2
