Belly mowers for superC
Bruce
03-12-2001 12:00:17
I have an opportunity to buy a Woods belly mower which according to the owner was set up for a Cub. Will it work on a C. Also how can you set up a belly mower to raies hydrolically rather than manually on a C?
David A
03-13-2001 06:22:55
 Re: belly mowers for superC in reply to Bruce, 03-12-2001 12:00:17
Bruce,
Drop by your Woods dealer at pick up the brochure on Woods mowers for vintage tractors. It lists all the Woods belly mowers (there were more than I thought). It has an applications chart matching mower to tractor including bracket kits. Best of all it has good pic's of mounted mowers.
Chuckb
03-12-2001 19:12:23
If you want to see a picture of a tractor with a belly mower with a manual lift, look at the Farmall A on the cover of How to Restore Your Farm Tractor. It's availabe at most major book stores or someone my have one you can look at. I also saw another manual lift on a Cub for sale. It was homemade but worked very well. It was a small wormdrive hand winch with pulleys and cable and mounted so the operator could operate it from the seat.
potosi
03-12-2001 16:38:55
One thing also to look out for is the cub power take off runs backwards to the C.
mike
03-12-2001 12:33:58
The mower itself will work,but the right brackets
could cost more than the mower.If your C has
hydraulic lift,a chain hooks to the right arm
and goes down to the mower deck.A friend of mine
just sold a 2 year old woods mower off of a C.
He didn't need it.He got 500.00.
