706 farmall 310GD coldblooded
Brent Combs
03-14-2001 21:43:51
I bought a F706 with the german diesel engine. I have another one that I bought brand new. The one I recently purchased is very coldblooded. If it is 50 degrees or colder I have to use ether to start it and after it is running I have to intermittently give it ether for about 5 minutes until the engine finally runs good. It smokes white just a touch too but not very bad. (I don't think it is a head gasket) The one I have always had is just the opposite it starts good down to 30 degrees and if it is colder than that it usually starts good and runs good with just 1 shot of ether. The only difference I see physically in the 2 tractors is that the problem tractor has a smaller diesel injection pump. I have talked to a few caseih mechanics and they tell me more than likely it is not the cause of the smaller pump because usually the smaller pump is more trouble free than the bigger one and in fact the bigger one is no longer available. Any help would be much greatly appreciated. Also one more thing I should mention. If I plug in the block heater on the problem tractor it will start and run good also down to below 10 degees.
stevie_alc
03-15-2001 09:01:54
 Re: 706 farmall 310GD coldblooded in reply to Brent Combs, 03-14-2001 21:43:51
I have one of those with 7400 hrs on it. I always use my block heater when it is cold. I have had no problem with starting. Make sure your fuel filters are clean and the fuel is good. I dont have to use either start and dont like to do that anyway. Good luck. Otherwise how do you like the tractor and what are they worth in your area?
Jim
03-15-2001 07:33:10
The D310 diesel engines will act cold blooded and start hard if the valves are recessed in the head.
peterc
03-15-2001 04:25:37
not unusual for deisel to be cold blooded . use the block heater and you will be fine.
Ace Schrunk
03-15-2001 04:49:11
 Re: Re: 706 farmall 310GD coldblooded in reply to peterc, 03-15-2001 04:25:37
Most Likly the valves are not seating good Diesels not cold blooded if they are in top shap if valves and rings not food they will start hard
