560 Hydraulic problem
Al Ward
03-22-2001 14:29:23
The loader on my Dad's 560 will only go down no matter what he does to the control position. Any Ideas He lives in Northern Mn.
DY
03-22-2001 17:47:55
 Re: 560 Hydraulic problem in reply to Al Ward, 03-22-2001 14:29:23
Oil level OK?
In front of the gear shift lever, about 6" above the trans. top there are selectors for single acting or double acting cylinders. Are they set to the D?
There is an orfice- screen assembly in the housing with the relief valve. That can cause stuff not to work.
Al Ward
03-22-2001 19:21:05
 Re: Re: 560 Hydraulic problem in reply to DY, 03-22-2001 17:47:55
Dad did check the fluid level & had the pump out & checked & both were fine.
Al Ward
03-22-2001 19:19:56
