O-RINGS OR GASKET?
bob[pa]
03-22-2001 17:31:50
the tubes that come out of hydraulic pump and run to the cylinders on a super A. is there gaskets or o-rings seals under that tubing mount? was wondering you have to remove these when you spilt tractor at rear of motor?
thanks for the help bob
gene b
03-23-2001 05:19:16
 Re: O-RINGS OR GASKET? in reply to bob[pa], 03-22-2001 17:31:50
the screw in the pump housing is a good way to prime the pump when finished might want to replace the seal on the pump while you are down when done remove the screw there is a spring in there but it sure makes it easy to prime the pump
Vern
03-22-2001 22:14:19
The front connection uses "o-rings" and the rear uses a gasket. Yes I think you will need to remove the rear connection from the unit to split the tractor.
