Order Farmall Cub Parts Online
Cub Timing
Bill VanHooser
03-23-2001 14:38:03
I have a 48 Cub with J4 Magneto ignition. I’m in the middle of an engine tune-up. Before removing the old points I checked the timing of the impulse coupler and found that the click occurred at the first notch (16° BTDC). This is not correct – it should occur at TDC with the engine off. My question is when I rotate the engine to TDC, does it matter which direction I rotate the magneto? Also, I assume it is the magneto flange mounting assembly that I rotate. I have read the service manual and reviewed the archives and this is not described clearly. Any suggestions or pointers will be greatly appreciated.
