Lights for 1951 Super A
bg
03-23-2001 22:59:33
My new '51 has a tear-drop rear light, minus lens. The red bulb is intact,the clear bulb is broken. The right headlight is missing and the left one is the the flat-can type for selaed beam, not the tear-drop type. Which is the correct one for a '51? I kinda like the look of the tear-drop. I know a guy who has a Super A and a Cub, each of which has both types of headlights. Don't know why he hasn't paired them up on the tractors, but I can probably get one flat-can from him or a pair of tear-drops. Any suggestions?
RON/PA
03-25-2001 04:37:13
 Re: Lights for 1951 Super A in reply to bg, 03-23-2001 22:59:33
THE LIGHTS ON MY PRE-50 LOOK IDENTICAL TO THOSE PICTURED, WHEN I CONVERTED MINE TO 12 VOLT I REMOVED THEM AND REPLACED WITH LARGER LIGHTS. BUT AS I RECALL THEY HAD A SMALL 6 VOLT BULB IN THEM LOOKING MUCH LIKE TODAYS 1156 BULBS.
HOPE THIS HELPS
RON/PA
Tyler (MD)
03-24-2001 13:35:08
This is the light set up on my '50:
third party image
Notice the origin white wire ties in this photo: LOL
third party image
Parts manual doesn't help much and the "Originality Guide" said that IH had the sealed beam headlights in the early '50's. That's about all I know. (Aint much)
Tyman
1953, not 1951....bg
03-24-2001 11:33:20
Checkd the serial number again and find I have a 1953 Super A, if that makes any difference about the lights.
Tyler (MD)
03-24-2001 12:57:26
 Re: Re: Lights for 1951 Super A in reply to 1953, not 1951....bg, 03-24-2001 11:33:20
'53 instead of '51 would make a difference in the decals. Up to August 16, 1951 had the wavy "Super A" Cultivision decal (1001188R1) and after that was the solid white background "Super A" decal (1001474R1). "Super" was written in a curve above the "A".
This is the decal up to '51:
third party image
Don't have a pic of the other.
Tyman
David A
03-24-2001 05:50:03
My original '53 has the same rear light as you describe. The front are not exactly teardrop shape. Originaly they had a 6V sealed beam lamp with a nipple protruding through a hole in the rear to connect the wires to. This bulb type is expensive. The IH dealer had a somewhat flatter 6V sealed beam by GE that has screw terminals on the back. The wires go in the rear housing hole and connect to the bulb. They mount with the original rubber ring. A pretty good near original solution I thought.
Haas
03-24-2001 05:44:45
I believe the correct lights for your tractor are the teardrop lights. I think the sealed beams came later. You can buy a bulb at any automotive supply that will fit the teardrop (either 6 or 12 volts. The bulb will be round instead of the flat top bulb like the original. I have a couple of 6 v original bulbs if you are interested.
gene b
03-24-2001 02:34:55
the teardrop lites came after 51 dont know for surenew teardrops are 50 each parts are also expensive check for good used ones lens-20 rubber gasket-5 bulb-5 they can run into money hopes this helps
