Main bearings
Bob
03-27-2001 20:18:00
Does anyone know where I can get a set of .003 undersize main bearings for my 400? I've tried Tractor Supply and NAPA but all they have is Std, .010 and .020. I will try Case/IH tomorrow. According to my IT book .003 are supposed to be available. I'm in the process of overhauling the engine and the mains are round but plastigage .005 with the old bearings, so I could get by with .002 if necessary. Help?!
jerry gerthofer
03-28-2001 19:01:59
 Re: main bearings in reply to Bob, 03-27-2001 20:18:00
might have to special order them right from the factory
jerry gerthofer
03-28-2001 18:54:47
Craig
03-28-2001 17:26:31
Why not just have the crank ground to .10 under? Ifyour mains are worn, the most likly your rod bearings will be also. If you have the resources, you will be better off in the long run....How is your oil pressure?
