Water jacket plate on an H
Ben
03-29-2001 20:23:05
Does anyone have maybe a nos water jacket plate they would like to sell. (also i need a gasket if you have one) Or is Bates Corp a good place to order one from? Getting ready to paint this next week and i cant get the old one to seal up. Any help is appreciated.Thanks
The Red
03-30-2001 05:53:35
 Re: water jacket plate on an H in reply to Ben, 03-29-2001 20:23:05
I have ordered from Bates before and they do a good job. You might check with Ken Updike also. 608-455-2411.
Charlie
03-30-2001 05:19:43
You mention the old plate won't seal. I had to change the block in my H and when I put the plate on it wouldn't seal. I was using a gasket kit from Central Tractor. I went to IH dealer and got a gasket and it worked fine. The C and T gasket wasn't quite as thick and it wouldn't work.
Justin
03-30-2001 04:33:47
The water jacket plate is still available from Case IH. I think it runs about $85. The aftermarket ones are junk. I have ordered numerous ones for Hs and Ms, and the baffles are placed wrong, so you either have to cut them back or take them off and weld them to the correct position.
