Buying an H
Bill
04-02-2001 08:06:44
Ihave a choice of 2 H one a 47 one a45/44
Both run good the 47 has duel narrow front wheels
the 44 a single Wheel and a complete set of cultivators it looks rough though. price is the same for either .1000$ and one have opinions of thing i can look for to help me decide?I'm leaning twords the 44/45 Thanks Bill
47 2N /53 Jubilee/2000Kubtoa
and an H?
Farmall43
04-02-2001 13:34:40
 Re: Buying an H in reply to Bill, 04-02-2001 08:06:44
I personly would go fo the single front wheel. But I like the ones that are not quite as common. At $1000 ea. and if they run good and the tires are decsant they are priced very reasanible, at least in my area. Whichever on you chose though I believe you will be pleased with. If you are going to put a loader on it you might want the 47'. I cannot imagine how much trouble it would be to change a flat on the single with a loader on it. I'm dreading changing the single on my F-12 this spring. Well good luck and happy buying.
Phil Auten (TX)
04-02-2001 09:03:03
And, I've been told that the single front steers easier!
No verification on this, however so you might want to try both.
One drawback to the single front is when you have a flat they are harder to remove.
Phil
The Red
04-02-2001 08:53:46
Bill if the rubber is good, either machine would be fine. I personally would opt for the 1947. If you have a need for the cultivators then the 44/45 might be your best option. The 44/45 with the single wheel is not as common as the standard dual wheels.
Dick Davis
04-03-2001 02:34:26
 Re: Re: Buying an H in reply to The Red, 04-02-2001 08:53:46
Both. This choice will eliminate the very difficult but inevitable question of, "What should I buy for my second tractor?"
