Voltage Regulator
Bob
04-04-2001 05:30:36
I was working on my tractor and the amp. meter was registering plus with the tractor running. Then for no reason the next time I started the tractor the amp. meter stopped registering and the battery would get weak. I did the testing and nothing helped, so removed the cover and pressed on the lower points with a screw driver the points closed and all was working well again. Is there a way to give it a little more pressure? I didn't see any adjustments in there. Thanks! Any help greatly appreciated! Bob
Bob/Maine
04-04-2001 06:01:44
 Re: Voltage Regulator in reply to Bob, 04-04-2001 05:30:36
Thanks! I will give it a try and get back with you. Bob
Bob M
04-04-2001 08:45:22
 Re: Re: Voltage Regulator in reply to Bob/Maine, 04-04-2001 06:01:44
Bob - Before you try adjusting the relay spring tension, make sure there's a good solid ground connection between the regulator base and the tractor frame. A poor regulator ground can cause exactly the charging problem you describe.
Also if you do wind up reducing the relay spring tension, make sure the relay drops (the contacts open back up) when the engine stops. If the relay doesn't drop when the engine stops it'll run the battery down real quick. ...Bob M
Bob
04-04-2001 09:02:49
 Re: Re: Re: Voltage Regulator in reply to Bob M, 04-04-2001 08:45:22
Hi Bob M: Thanks! I will look for the problem and get back with you on how I made out.
Bob
The Red
04-04-2001 05:47:42
Bob see if the back side of those points have a small arm with a tension spring. If they do, slightly bend that arm so there is less tension on the spring.
