Order Farmall Cub Parts Online
McCormick IH Farmall Cub circa 1973
Bob Jones
04-08-2001 14:47:21
The left brake works intermittently. Reaching into the housing to feel the "drum", it appears to be loose and the lining appears to be running half-way on it. Could someone please enlighten this novice on this problem? Could serious harm occur if I continue to operate the tractor before this problem is fixed?
Farmer Bob
04-08-2001 15:15:45
 Re: McCormick IH Farmall Cub circa 1973 in reply to Bob Jones, 04-08-2001 14:47:21
Bob, It could do serious damage or even lock up if the drum is loose not to mention the further damage you could do to the brake band and lining. Best to remove the final drive and check it out further.FB
