240 has the hic-ups
BobinIL
04-11-2001 06:30:43
I have a 240 utility with a 3 point hitch that has the hic-ups. When you raise an impliment and leave it up it leaks down about 2 inches and then jumps back up, over and over. What can I do to remedy this? Also when I pull the lever all the way back to lift the implement it pulls the engine down until I push the lever back down about 1/5th of the way then it stops pulling down the engine. Is there a way to adjust this to make it work properly?
Redneck farmer
04-11-2001 16:35:17
 Re: 240 has the hic-ups in reply to BobinIL, 04-11-2001 06:30:43
How worn is the cylinder.
bob w.
04-11-2001 11:21:11
if you leave the 3 point raised with the motor shut down does it drift all the way down , was your 240 originaly a fast hitch ? it sounds like your cylinder is by passing internaly , if it drifts down lift it up and place a jack under it then cap the lines off and remove the jack if it still drifts your cylinder is leaking internaly. also sounds like the linkage on the left side of the fast hitch that controls the control valve may be out of adjustment but i would fix the drifting problem first, it sounds like your fast hitch mechanism is trying to conpensate for a bad cylinder. hope this helps .
Rick in CA
04-11-2001 15:30:02
 Re: Re: 240 has the hic-ups in reply to bob w., 04-11-2001 11:21:11
Bob,
Funny you should ask this question. I have a 240 with the same problem and I plan on working on it this weekend. I asked a similar question a couple of weeks ago and received a response. The print-out I have of the reply doesn't have the name of the respondant on it so I can't give credit where it is due. His relpy to my inquiry is as follows.
"From your description I suspect that you have an obstruction in the line going to your cylinder. If the enginer gets loaded up when you raise or lower the lift without anything on it, chances are that the pump is putting out high pressure which isn't making it to the cylinder because of an obstruction, and the system's high pressure relief valve is (correctly) relieving this pressure before it gets dangerously high - but putting out this high pressure makes the engine work hard. If you don't notice any difference between how the system acts in the middle of the cylinder's travel and at the ends of it's travel, an obstruction is almost certantly the problem. Another tip off is if the rate at which the cylinder moves is very slow. The obstruction could be in the control valve somewhere. If you have more than one circuit in your hydraulics, a check of how one performs verses the other would be informative."
I do have dual system on my 240 and the other side works fine. I did rebuild my control valve and it didn't buy me anything. Next is to flush the line to the rear and rebuild the check valve under the seat (I think that's what it is)
Keep me updated on your progress. It may help both of us. Does anyone know how hard it is to rebuild the cylinder?
regards,
