Yumpin Yimeny Krickets-Carburetor
Bob
04-13-2001 11:54:48
I have a Zenith Carburetor. On the top is stamped a #14007, I have placed this on my Super C and have never had my tractor run smooth, too much gas. Is this carburetor to big for this tractor? Thanks! any help greatly appreciated! Bob
Tim - Maine
04-13-2001 17:56:22
 Re: Yumpin Yimeny Krickets-Carburetor in reply to Bob, 04-13-2001 11:54:48
Bob,
I could only find Zenith and Made in USA on the side of my carb but it is pretty coated in gunk, according to the manual that I have, the 123 motor only had the Zenith 67x7 or the Carter UT on it. I could fax you copies of the manual to look at the pictures if you have a fax available or I'll see if our scanner is working at work tomorrow and send them to you via e-mail.
Where are the numbers on the top of your carb? I believe from what I've read and just guesstimating by looking at my carb that the air inlet side is between 7/8 to 1 inch inside diameter, I'll be taking mine off soon and I'll definantly measure it at that time but I may not have time to do that until the Friday after next (27th???) when I get a full day off. We have an outage at the plant so I'll be working alot of overtime for the next week and a half.
Bob
04-14-2001 05:42:01
 Re: Re: Yumpin Yimeny Krickets-Carburetor in reply to Tim - Maine, 04-13-2001 17:56:22
Hi Tim, Thanks! The opening where the air comes in is 1.600" the number is right on the top just above the name Zenith on the upper section on the flat section. My fax # 627-7483 Thanks again. Bob
