130 runs rough
Benny
04-22-2001 20:32:29
Changed plugs and plug wires on my 130 and motor runs rough. Was running smoothly before plug change. Any help would be appreciated.
Red Dave
04-23-2001 09:42:26
 Re: 130 runs rough in reply to Benny, 04-22-2001 20:32:29
What kind of plug wires did you use? These tractors sometimes don't like the modern resistor/suppressor wire. Most folks have best luck with plain copper wires. You could also have a bad new plug. It shouldn't happen, but, sometimes it does.
Bob
04-23-2001 08:06:35
Hi Benny, Check and see if may be you broke a spark plug. Bob
Benny
04-23-2001 07:08:23
Thanks for the advice. The plug wires are on correctly. Is is possible that the valves need to be adjusted? Any help appreciated.
Dan 130
04-23-2001 04:49:59
It's very easy to get the plug wires installed wrong, even though it's only a 4 cyl. . If you have a manual, check your firing order and make sure # 1 cylinder matches # 1 on your distibuter. I did the same thing on my 130 when I changed the plug wires. If you want me to check anything on my 130 that will help you, let me know. Good luck!
planzman
04-23-2001 14:23:18
 Re: Re: 130 runs rough in reply to Dan 130, 04-23-2001 04:49:59
My 140 is very tempermental about trash in the opening at the bottom of the fuel tank. I replaced my metal line with a two piece rubber hose and some quick clamps. All I have to do is disconenct the hose and blow some air into the tank to clean the opening out. Eventually everything will pass through and settle in the bowl. Just everyonce in a while things get plugged up.
hopes this helps
Benny
04-23-2001 21:48:36
 Re: Re: Re: 130 runs rough in reply to planzman, 04-23-2001 14:23:18
I installed the regular copper plug wires. Today I adjusted the valves, reset the points and plugs, removed the carburetor and cleaned it, but she still won't smooth out. What next - should I replace the coil or something? I appreciate all your help.
Red Dave
04-24-2001 07:13:50
 Re: Re: Re: Re: 130 runs rough in reply to Benny, 04-23-2001 21:48:36
Just for the heck of it, put the old plugs back in and see if it smooths out.
Benny
04-24-2001 19:59:08
 Re: Re: Re: Re: Re: 130 runs rough in reply to Red Dave, 04-24-2001 07:13:50
I threw the old plugs away but I just ordered a new set. I will try that first. Thanks for the help.
