Bucket Cylindres on Loader
Brent
04-23-2001 05:56:22
I have a Koyker loader on my 560 and would like to replace the bucket cylinders as one is leaking through a non-weldable crack near a fitting. Prices are outragreous from the manufacturer, does anyone have a source for affordable after-market cylinders? The are about 22" center to center so I would guess about a 12-16 inch stroke.
Matt Clark
04-25-2001 13:34:02
 Re: Bucket Cylindres on Loader in reply to Brent, 04-23-2001 05:56:22
Who says it's "non-weldable"? I had a split fitting, local welder fixed, and then tapped, works fine, 2 years later.
Mark
04-23-2001 08:07:14
Try Northern Hydraulics or Northern Equipment, whatever they call it now, in Burnsville, Minnesota. I've had good luck buying cylinders, pumps, filters, tanks, fittings, the whole bit. They also sell books on hydraulic troubleshooting and repair. I used them to buy everything needed to make a stand-alone high-volume hydraulic pump unit that has been working OK for ten years. They have an on-line ordering system that actually works, plus you can call toll-free.
Strongly suggest you accurately measure everything about the cylinder you intend to replace, such as overall length when closed and extended, stroke length, clevis sizes and/or bolt pattern, hose fitting sizes, etc. Make sure you know the correct piston diameter. It would also be helpful if you had the Original Equipment Manufacturer serial numbers or any other codes available for the unit. That may help in cross-referencing. Some of this info is free for the asking at the manufacturer's website, etc.
All this being said, the cylinders are heavy and shipping costs need to be figured in. Make sure you add this into your overall cost estimates, and compare what you can get at a local dealer. If the dealer is remotely close in price, then buy local. That way if there is a problem or you need advice, you are not totally on your own.
Also consider checking with a local hydraulic service shop as far as available "generic" replacement cylinders. My experience with some AG equipment dealers is that their prices for certain items can be outrageous, just like auto dealers. As far as I can tell, the tractor manufacturers buy their hydraulic cylinders from other manufacturers anyway, so you may just be paying for the paint job.
If loader is a dual-cylinder setup, consider replacing both to insure equal function on both sides.
GSS
04-23-2001 12:38:22
 Re: Re: Bucket Cylindres on Loader in reply to Mark, 04-23-2001 08:07:14
Are they possible to rebuild yourself? A few of mine are leaking too.
- G
Drizler
04-23-2001 12:47:36
 Re: Re: Re: Bucket Cylindres on Loader in reply to GSS, 04-23-2001 12:38:22
Check with SURPLUS CENTER. In Lincoln NB. 800-448-3407. They have lots of hydraulic stuff, no web pagr or catalog though.
dan
04-23-2001 16:06:50
 Re: Re: Re: Re: Bucket Cylindres on Loader in reply to Drizler, 04-23-2001 12:47:36
surplus center is great and they do have a catolog,mine is at work. when i can i'll get the number and post it!
Drizler
04-23-2001 12:47:05
