SUPER A CLUTCH NOISE#%!
BOB[PA]
04-23-2001 17:09:41
MOWING WITH MY A THE OTHER DAY AND NOTICE SOME STRANGE NOISE AT CLUTCH AREA?
1-WHEN THIS NOISE HAPPENS PUSH PEDAL DOWN A LITTLE AND NOISE GOES AWAY
2-THE TUBE THAT THROW-OUT BEARING RIDES ON MOVES IN AND OUT A LITTLE WHEN YOU PUSH CLUTCH IN?
3- THIS TUBE LOOKS LIKE IT IS RUBBING HUB OF CLUTCH DISK WHEN IT MAKES THE NOISE? FOUND SOME FINE METAL PARTICALS ON THE PLUG YOU TAKE OUT TO LOOK INSIDE. PLUS DISK HUB IS SHINIE WHERE THIS RUBS
4-SORRY SUCH A LONG POST (BOB)
5-THANKS FOR ANY INSIGHT TO THIS PROBLEM.
Will
04-24-2001 04:02:32
 Re: SUPER A CLUTCH NOISE#%! in reply to BOB[PA], 04-23-2001 17:09:41
Bob, did you try greasing the thow-out bearing,there,s a hole on left side of housing with a cover over it.Grease fitting is straight in.
bob[pa]
04-24-2001 17:28:56
 Re: Re: SUPER A CLUTCH NOISE#%! in reply to Will, 04-24-2001 04:02:32
yes WILL i did grease the bearing looked again at it alittle closer this tube is cracking at end from hitting disk hub.
thanks again bob
jerry Gerthofer
04-23-2001 18:16:04
this is nothing out of the ordinary as you explained. I would not worry about it
