IH Two Bottom Plow ID
Bob R
04-24-2001 17:35:58
Hi ,
I am interested in knowing the year and plow imfo .
The number on the plow is IH PO17184 .
Any imformation appreciated . Its a two bottom trailer type .
Thanks
gene b
04-27-2001 21:23:05
 Re: IH Two Bottom Plow ID in reply to Bob R, 04-24-2001 17:35:58
here we go the 10in bottom built from27-53 the 12 and 14 built 27-61 the 16 built from 29-61 the part no you gave is for the first beam used from 37 and on it is a NO.8 FORMERLY CALLED genius made two and three bottom rubber or steel wheels this info comes from the parts book revised 2-58 hopes this answers your questions glad to help GENE B
Bob R
04-28-2001 09:05:36
 Re: Re: IH Two Bottom Plow ID in reply to gene b, 04-27-2001 21:23:05
Thanks
I have a 14" two botton plow on rubber tires . You have a grease fitting for the cutter wheel . Has the cam for
pulling the rope to engage lift or down .
The spring on the front will kick the unit off the draw bar if a rock is hit hard .
It needs some work .
Appreciate the reply
Take care
Bob
gene b
04-24-2001 17:59:27
does it have a trip rope or has it been changed to hy or is the hy original rubber or steel are the rims spoke or steel with solid centers is it a 12 or 14 or a 16 in bottoms do you have sealed bearings in the rolling cutters do you have joiners do they mount on the rolling cutters or mount on the frame measure the beams for distance this will tell whether 12,14,16in does the shares have removable points or is the share solid one piece the numbers on the beams will tell me the model I have a book on the plows numbers on the bottoms wont prove anything as there were many different styles for each model be glad to look up the info thanx
bob r Will get the pertinents for you Thanks
04-25-2001 08:08:31
 Re: Re: IH Two Bottom Plow ID in reply to gene b, 04-24-2001 17:59:27
Thanks Will look at it again
Matt Sheaffer
04-24-2001 17:44:40
I have a IH 2 bottom plow with almost the same numbers but mine goes PO17164 I think. And it is a little wonder plow
gene b
04-27-2001 21:34:52
 Re: Re: IH Two Bottom Plow ID in reply to Matt Sheaffer, 04-24-2001 17:44:40
according to the parts boof the little wonder was only one bottom 14 or 16 the no 3 calledlittle wonder made from 40-55 no part no in book 17164 maybe the 6 is really an 8 look again
