F12 dual fuel gas tank question.
Brian
04-27-2001 05:48:03
I have a '35 F12 with the dual fuel gas tank that is the tank inside a tank style. Now I don't plan on running this tractor on kerosene so I will obviously just fill the big tank with gas and so what should I do about the small tank. I don't want it to rust out from just sitting there or should I fill it with gas and just open both petcocks when running.....small dilema.
MikeH-Tx
04-27-2001 07:25:09
 Re: F12 dual fuel gas tank question. in reply to Brian, 04-27-2001 05:48:03
I use the little tank on mine more than the big one. However, both petcocks drip a little, so I don't usually leave gas in the tanks for any time at all.
The only wrong thing to do is to half fill a tank with gas. That causes heating and cooling of the air above it and causes condensation, then rust. Leaving it empty will not cause it to rust out.
MikeH-Tx missed something
04-27-2001 16:17:17
 Re: Re: F12 dual fuel gas tank question. in reply to MikeH-Tx, 04-27-2001 07:25:09
If you open both petcocks and put gas into one tank, the gas will equalize levels in both tanks resulting in a half full condition that will cause condensation like I mentioned.
I would just leave one shut off and use the other.
