IH Two Bottom Plow Number For Gene
Bob R
04-29-2001 17:34:52
Hey Gene
I went and looked again . the number is:PO17184
on the frame . Thanks for all your responces so far ...
This was the rope type 14" bottom . On rubber .
Has a grease fitting on the cutter wheel .
Will any 16" tire work on this or should it have tread to work ?
This looks ugly now , tire are all rotted off .
Has GREEN mold on it . Have to be sure its RED again , Ha
gene b
04-30-2001 03:10:27
 Re: IH Two Bottom Plow Number For Gene in reply to Bob R, 04-29-2001 17:34:52
you must not have seen the reply it is a NO 8 that part no is for the main beam they made 10in 12in 14in and 16in bottoms rubber steel hy lift and clutch lift yes any tire will work used to have to put a chain on sometimes in tough sod as the plow was hard to lift up might as well find a good used one and white wall for pretty do you need the paint scheme
Bob R
05-01-2001 12:38:38
 Re: Re: IH Two Bottom Plow Number For Gene in reply to gene b, 04-30-2001 03:10:27
Yes I saw the reply , But was thinking the year might get narrowed down .
I could use the paint scheme too .
Thank you for all the help
