140 Pesco Pump Replacement
Bob
04-29-2001 19:48:18
Can anyone tell me if there is a replacement pump for the 140 hydraulic pump. The brass and rubber M shaped seal inside the pump has worn out and caused the oil seal around the shaft to fail. Is International dealer my only option? Thanks, Bob
hendrik
04-29-2001 23:07:17
 Re: 140 Pesco Pump Replacement in reply to Bob, 04-29-2001 19:48:18
Gene B says that if the seal leaks because of a worn shaft, place a speedy sleeve on the shaft and put in a new seal. This will fix the leak. If it appears to be necessary for my Super A pump I will certainly try. You buy speedy sleeves in a good bearing shop. They cost their weight in gold; for the pump shaft aprox. 20 dollars.
Good luck. Hendrik.
justin
04-29-2001 20:23:48
I have a New Old Stock Hydraulic pump for the 140 for sale. Email me, or give me a call at (507) 434-0876. The part number of the pump is 383013R94.
