Farmall M Rim Repair
HELP!
Bama Red
05-01-2001 05:44:26
I've got a 10 x 38 rim which is rusted out by the valve stem (not unusual, I understand). I want to remove the tire, cut out the weak metal and weld a plate in place from the inside and then drill a new hole for a valve stem. Is this a realistic repair? Has anyone done this type of repair. Several of the farmers in my area say it can be done. I haven't been able to find a used rim and can't afford a new one.
Zonie
05-01-2001 15:38:06
 Re: Farmall M Rim Repair - HELP! in reply to Bama Red, 05-01-2001 05:44:26
Bama,
Are you sure you have 10 inch rims? My H has 11" rims and most M's I've seen have 12".
Haas
05-01-2001 18:49:39
 Re: Re: Farmall M Rim Repair - HELP! in reply to Zonie, 05-01-2001 15:38:06
My observation is that most H's have 10 inch rims and most M's have 11 inch rims. I believe the Super Ms mostly have 12 inch rims.
will
05-01-2001 14:52:54
B RED,you don,t have to put the valve stem back in the same spot,go to another part of the rim that is in good shape if possible and drill a new hole,and repair the old callcium eaten area.
Haas
05-01-2001 06:30:02
I had the same problem with my C. I don't do welding, but took the rim to the shop that does my welding. They trimmed up at the hole back to sound metal and welded in a new piece of metal and then drilled a new hole for the valve stem. I think they charged me $15. You also need to clean off all the rust scale from the inside of the rims and paint them. I found that an air hammer with a blunt chisel on it works great for that. You just can't get that heavy scale off with a wire brush. After that use a wire wheel on an angle grinder. Be sure to wear your safety equipment. Eye protection, hearing protection and heavy gloves.
Bama Red ...and Question for Haas
05-01-2001 06:53:16
 Re: Re: Farmall M Rim Repair - HELP! in reply to Haas, 05-01-2001 06:30:02
Thanks, Mel, Charlie & Haas.
Hey Haas - didja see my post to you further down the page? Take a look and let me know. Rick
haas
05-01-2001 07:08:24
 Re: Re: Re: Farmall M Rim Repair - HELP! in reply to Bama Red ...and Question for Haas, 05-01-2001 06:53:16
Yes saw it. Couple of comments there. If the MD was running good, that was a good price. Good price for that Cub too.
05-01-2001 07:24:14
 Re: Re: Re: Re: Farmall M Rim Repair - HELP! in reply to haas, 05-01-2001 07:08:24
Sorry bout that! I hadn't hit the refresh button in a while. Wish I had remembered that show in Gray - got a bad case of CRS (can't remember shutt) - must be my advancin' age an' general decrepitude. Onliest thing I got was a 7' pull-type sickle bar mower and a slip clutch for my M. Got the mower for only $150.00 - its a New Idea and is in real good shape.
Haas
05-01-2001 18:15:02
 Re: Re: Re: Re: Re: Farmall M Rim Repair - HELP! in reply to Bama Red ...and Question for Haas, 05-01-2001 07:24:14
I like that mower! Especially the price. Is it a belt drive or dos it have a pitman? I bought a 3 pt hitch New Holland about a month ago for a lot more than that. Not too crazy about a pull type, but for that price I could have made it work.
Bama Red
05-01-2001 20:38:52
 Re: Re: Re: Re: Re: Re: Farmall M Rim Repair - HELP! in reply to Haas, 05-01-2001 18:15:02
Haas - It has a pitman - in fact a brand new one which was made for it just before the sale. Everything about the mower gives the notion that it was well taken care of: there's grease in all the zerks, no missing teeth, good sharpening job on the blade, etc. I think I got a real steal. Sorry bout the bad pics, but the pics were taken early Monday morning before there was good light cause I had to head back to Huntsville for the work week. I'll be back at the farm for the weekend.
mel
05-01-2001 05:58:27
I took a rim for my super C to the local welding shop and they did a beautiful job of welding a small plate with a drilled hole to the rim. From the outside you couldn't tell it was repaired after it was painted. Now these guys are good and that makes a big difference.
Charlie
05-01-2001 05:54:48
I have a friend who has done it before. You just need to have a good welder so its a quality job when finished.
