Farmall C
Brian
05-11-2001 07:01:05
My Dad called me today and said he had a line on a Farmall C. He didn't have time to give me any particulars on it.
Can someone give me somethings to look for if we look at this? Also, is there a general price range that this should fall into?
Thanks in advance.
Haas PS
05-11-2001 13:51:13
 Re: Farmall C in reply to Brian, 05-11-2001 07:01:05
Forgot to tell you. Check the engine block behind the carburator. It it has ever frozen, that is where they break. It's not uncommon to find them welded there. If it's a good repair, the tractor is still ok.
Haas
05-11-2001 13:48:14
Anywhere from $500 to $2500 depending on the condition. Should run good and not smoke. Check the steering to see that it does not have a lot of play. Check the tires and rims. Rims to see they are solid and not rusted out. They will likely have some rust, but should be solid. Check it out in all gears and check the clutch to make sure it is not slipping.
