Loader ???'s
1PWRFULH
05-11-2001 20:07:34
Well Well Guys, I finally got the loader that I bought for the H sandblased and painted. That thing looks real sweeet! I can't wait to get the thing on the tractor and start doing some work. But, I have one question, does anyone know what size bolts and how many to put the loader on the tractor? Also, should I run a return line from each cylinder or just have one line going to each cylinder? Thanks!!
RC
JLE
05-12-2001 03:18:34
 Re: Loader ???'s in reply to 1PWRFULH, 05-11-2001 20:07:34
If you have a 30 or 31 IH loader, there was a tee at top of filler pipe with short piece of pipe the right side and a longer pipe to the left side, the hoses on the rod end of the loader cylinders connected there.
Dick Davis
05-12-2001 02:55:04
Use the largest bolts that will fit through the brackets, grade 5 or better, and keep them tight. They will take a lot of abuse and having them fail is not good. If you are running the belly pump just run one line to each cylinder and vent the other port. D-2
