Another Loader Question
1PWRFULH
05-12-2001 15:14:24
Hello, Well since I am getting ready to install the model 31 loader onto my H I was just wondering if I have all the brackets and everything? Check the link below to see. I swear I think that I am missing something? Also, where do the tubular arms come down and hook too? Thanks in advance!
P.S. The loader looks brand new now!
Bill C
05-13-2001 18:10:17
 Re: Another Loader Question in reply to 1PWRFULH, 05-12-2001 15:14:24
The brackets you have circled,bolt on to the tractor on the very front of the upper bolster, ahead of the frame rails,the bracket that is floating in the air in the picture angles back and bolts on where the frame rails meet the upper bolster.The tubes that are mounted near the tripping mechanism for the bucket ,will pivot,and limit the loaders side to side sway.The tubular brackets bolt to the top of the rear upright support,on one end,and the front holes in the top and bottom rows of holes in the frame rails(the holes used for mounting cultivators).Then you need a set of brackets that clamp around the axle housings to mount the rear uprights to.
