Axle sizes
Ben
02-17-1999 05:58:40
Did the H and the M have the same size rear axles?
Did the 460 and the 560 have the same size rear axles?
Thanks.
-ben
john d.
02-17-1999 15:34:43
 Re: axle sizes in reply to Ben, 02-17-1999 05:58:40
H and M do NOT have the same size axles. M axles are much heavier. M and 560 axles are the same diameter. Pretty sure that H and 460 axles share the same diameter.
John you are correct
02-18-1999 12:09:44
 Re: Re: axle sizes in reply to john d., 02-17-1999 15:34:43
John,
You are correct. The H, 300, 350 and 460 have the same size axles and the axles on the M, 400, 450 and 560 are the same size.
Jason
02-17-1999 07:13:50
I'm not sure about the h and m size being the same but I know u can swap wheel centers on an f-12 and an H.
Farmall gray
02-23-1999 18:52:02
 Re: Re: axle sizes in reply to Jason, 02-17-1999 07:13:50
You can swap them but it doesnt work very well.
An H has a 2-1/2" axle and the F-12 has a 2-5/8"
axle. I know because I have an F-12 with H wheels on it-they are always coming loose. The hole in the wheel is too small for the axle. (yes that is correct, the H has a SMALLER axle than the F-12)
Wayne
02-17-1999 10:14:31
An M has larger axles than an H. It has been a long time since I have seen a 460. I think the 460 could have the larger axles I know they put 2MH pickers on them and they were heavy. But the housings were smaller.
Don Summers
02-17-1999 19:53:22
 Re: Re: Re: axle sizes in reply to Wayne, 02-17-1999 10:14:31
The early 460 had the same size axle as the 350. I have a '62 model 460 Diesel and it has larger axles. The early 460 and 560 both had smaller axles and IH had to take a lot of the first ones back to the factory and rebuild the transmissions and rear ends because they would not stand the hp from the stronger 6 cylinder engines.
Don Summers
02-18-1999 15:12:36
 Re: Re: Re: Re: axle sizes in reply to Don Summers, 02-17-1999 19:53:22
I have a 1958 model 350 and a 1962 model 460 and the 460 axles are bigger than the 350 axles.
Jon S.
02-18-1999 10:52:23
Farmall F-12 Steel Wheels will fit on an H Farmall pretty good but Factory H STeel Wheels do not fit on an F-12....IT's close but the clamp bottoms out before it can slip on the F-12 axle....Tried it and it won't work.
Chris M.
02-17-1999 20:39:34
I have a 1959 Farmall 460 and I took a pair of non-power adjust centers off a 560 for it. To the best of my knowlege, the 460 could be ordered with either the Std. axles or with what they called HD axles.
