Order Farmall Cub Parts Online
Cub Cooling System
Bill Swope
02-17-1999 13:58:44
Purchased a Cub 1958 model and was surprised to find that it does not have a water pump. How does this system work and are there any special problems in using the tractor per cooling? I have run it a little and did notice that some steam was popping out the radiator but it did not seem overly hot.
mark
02-17-1999 17:54:28
 Re: Cub Cooling System in reply to Bill Swope, 02-17-1999 13:58:44
The posts below accurately describe what's known as "thermosiphon."
JW
02-17-1999 17:04:04
The cub is cooled by convection. As water gets hotter, it becomes less dense. Therefore the hotter water rises to the top, and also the cooler (more denser) water sinks to the bottom, therefore creating a circulating pattern within the system.
billy edmondson
02-17-1999 16:37:37
as the water heats in the engineit is forsedinto the radiator where it cools Iv used a cub for 20 years to mow my yard .just add water and go on
Mey (NH)
02-17-1999 14:21:46
Bill, you're right there is no pump, the cubs use a siphen, gravity system. It is recomended that a non-preasure radiator cap be used. Over filling the sytem can lead to coolant spilling from the radiator, but it is not a danger unless the system really overheats and gets low on coolant.
Mey
