H
truns over slow
Bert
02-20-1999 10:15:45
got an H that is hard to start,Replaced the starter from my M didnt seem to help put in a 8 volt battery didnt help, it just dont seem to spin like it should ,warm or cold checked the timing seems to be ok, points plups . pull it 1 foot and it running, dont know what to do with it thanks
Bill
02-20-1999 16:10:57
 Re: H - truns over slow in reply to Bert, 02-20-1999 10:15:45
The 6 volt starters have a tendency to "drag"if everything is not just right. I would check cables,all connections& starter button. I had an H that did the same thing. finaly went to 12 volt system & solved the problem.
john d.
02-20-1999 11:09:25
Check to see if your battery cables, or the cable from the starter switch to the starter need replacing. Bad or loose connections to these components or ground, or cables that have been replaced with wire that's too small will do this. Also a possibility that the starter switch isn't making good contact. A far-out possibility would be that someone has tinkered with the engine to raise compression, but that's a very long shot.
